10-16-2018
19:40
15:06
10-16-2018
19:40
15:06
Hi
Does anyone know where the quick view setting is on the charge 3 as I want to stop the light coming on in the night. This worked for the charge 2 but I can't find the setting on the charge 3.
Thanks
10-16-2018 20:07
10-16-2018 20:07
I believe what you want is to hold the haptic button for an extra second or two until you see the "screen wake" and "notifications" icons. Tap the "screen wake" and that will turn it off.
10-16-2018 20:07
10-16-2018 20:07
10-19-2018 01:48
10-19-2018 01:48
Perfect thank you I also was after an answer to this question, you got it spot on thank you
Best Answer10-19-2018 03:06
10-19-2018 03:06
Thanks for your help
Best Answer01-04-2019 06:21
01-04-2019 06:21
I cannot get Fitbit to turn on to sync to Bluetooth on 8+ phone. Where is the on off button?
Best Answer01-06-2019 23:31
01-06-2019 23:31
Best Answer03-01-2019 05:44
03-01-2019 05:44
Thank you!!! It was driving me crazy that I couldn’t find it. ☺️
Best Answer07-31-2019 23:37
07-31-2019 23:37
That worked great! I had looked on a Fitbit community site online and it didn't offer this simple solution. It is what I needed!
14:50
06:40
AndreaFitbit
06-29-2020
14:50
06:40
AndreaFitbit
Did not work for me. I found and tapped the "screen wake" but every time I move my hand the screen still turns on. Any more suggestions on how to turn the screen off?
Moderator edit: format.
