08-15-2019
03:36
13:47
08-15-2019
03:36
13:47
So whent spinning today and when I went to select it on my charge 2 it had gone and bin replaced with elliptical can any one help me get spinning back it's not on the app ether don't no if it gone with the new update but would be nice to know thanks
08-15-2019 23:47 - edited 08-15-2019 23:48
Hi @Cianc17 Welcome to the Community. You should be able to add spinning back in to the exercise shortcuts. Go into your app and tap on your Charge 2, scroll down and tap on exercise shortcuts towards the bottom.
You can only have 7 shortcuts at a time so if you have 7 you will need to delete one. To do this tap on one of the unwanted short cuts and swipe to the left to remove it.
To add spinning tap on the + symbol top right and select spinning from the list and tap on add to Charge 2 at the bottom.
Finally resync your Charge 2 to update it and you will be good to go.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
Best Answer08-15-2019 23:47 - edited 08-15-2019 23:48
Tony | UK
Best Answer08-16-2019 00:58
08-16-2019 00:58
Chears thanks for the help
08-16-2019 02:17
08-16-2019 02:17
Your welcome, glad it helped.
Tony | UK
