08-28-2019
20:00
10:43
08-28-2019
20:00
10:43
Recently the screen of my fitbit charge 3 went all weird, there's white stripes going from the top to the bottom, and as well as that, the screen doesn't respond to my touches well anymore and when I squeeze the side to turn it off if it's on it just glitches and flicks on and off. To my knowledge nothing had happened to cause this, I had checked the time before lunch to see how far away it was and then I checked once again during lunch, and when I checked at around 12:45 the screen was all funky and it wasn't working well. The battery also seems to be dying quicker than it used to. My boyfriend did drop it about 3 months ago and there's a chip in the screen, but it never affected it so it can't be that.
08-29-2019 02:38
08-29-2019 02:38
Hi @JensenA Try restarting your Charge 3 several times. If that doesnt help then please come back here.
Helen | Western Australia
09-02-2019 19:55
09-02-2019 19:55
The screen on my
charge3 now has vertical black line through the display. What causes it? Do I need to enact warranty claim?
Best Answer09-03-2019 02:07
09-03-2019 02:07
@JensenA @SunsetRunner Try restarting your Charge 3 several times and try a Long Restart. If neither of these help please come back here.
CHARGE 3 LONG RESTART
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
09-03-2019 03:36
09-03-2019 03:36
Best Answer09-03-2019 05:44
09-03-2019 05:44
@JensenA I have flagged a moderator to come and help you
09-03-2019 07:30
09-03-2019 07:30
Best Answer09-03-2019 08:19
09-03-2019 08:19
Hey @JensenA and @SunsetRunner, thanks for posting your inquiry here. Welcome to the Fitbit Community @SunsetRunner.
Thank you for pointing this out @NellyG, I'll be glad to help.
@JensenA, I just confirmed with the Support Team that you have already an open case. The team in charge is currently working on it and waiting for your reply. I recommend you to continue the assistance with they.
@SunsetRunner, in order to further assist you can you confirm please, if you tried those restarts and what is the result?
If you have any further questions, please let me know!
Best Answer09-03-2019 08:45
09-03-2019 08:45
Best Answer09-03-2019 20:44
09-03-2019 20:44
I’ve tried restarting several times and long restart. It does not come back to smiley face, just shows charge %. (I always have trouble lining up the pins for charge connection, it should be
easier.)
Best Answer09-03-2019 20:46
09-03-2019 20:46
Yes, I tried several restarts, but it does not come back to smiley face after long restart.
Best Answer09-06-2019 15:53
09-06-2019 15:53
Best Answer09-07-2019 18:51
09-07-2019 18:51
I brought up this issue a while ago, how my screen no longer reacts to my touch most of the time, glitches when I press the side to turn it off, the white lines that cover the screen, and it dies quicker than it used to. My year warranty isn't up yet, and I've tried resetting it multiple times and everything and it's still broken and no one has further helped me yet. My fitbit has been broken for almost a month now and I have yet to either get an answer to fix it or send it back and receive a new one.
Best Answer01-17-2020 04:05
01-17-2020 04:05
Hi, I'm having the same issue, it happened yesterday, typically 1 year and 1 week into my fitbit ownership. It asked me to recharge my Fitbit, I did as it only had 6% charge left. when I went back the screen was covered in white and grey lines (pixelated) with a black stripe/line a little below the centre line of the screen. I cheched my mobile device and it said the fitbit was 100% charged. I have followed the advice given here and have long/hard reset the Fitbit about 6 times since discovering the fault. This has not solved the issue. It's still showing while/grey and single black line(s). I use the Fitbit to track walking, swimming, treking, gym, pilates and yoga events regularity. It hasn't been dropped or crushed, it has been well maintained and looked after. I am at a loss why it has "died" on me. It's quite disappointing that it hasn't lasted more than a year if it is a technical fault. What are the options to get the screen back as there hasn't been any answers posted.
01-17-2020 10:44
01-17-2020 10:44
Best Answer01-17-2020 13:00
01-17-2020 13:00
Best Answer01-18-2020 00:47
01-18-2020 00:47
Best Answer01-18-2020 11:57
01-18-2020 11:57
Best Answer01-18-2020 12:30
01-18-2020 12:30
Hi there,
I have just started having this problem and have restarted, rebooted, wiped, and reset my device, with no luck in getting the screen to calm down. Also, I had a good amount of battery left and woke up with it saying it needed to be plugged in, then I plugged it in after it told me it had 6% and immediately it started charging saying the battery was at 90% already. Something is clearly wrong here, and I have not found a chat feature to talk to anyone about this.
Best Answer01-23-2020 06:06
01-23-2020 06:06
