08-20-2018
13:18
15:47
08-20-2018
13:18
15:47
This may be the upgrade we are looking for IF the Charge 3 includes a Countdown timer. (Not just a stopwatch or alarm.)
09-29-2018 05:09
09-29-2018 05:09
The manual is now available and confirms that there is a countdown timer. See page 27 of:
https://staticcs.fitbit.com/content/assets/help/manuals/manual_charge_3_en_US.pdf
08-20-2018 14:50
08-20-2018 14:50
Looking at the Spec no it does not have as count down timer
Wendy | CA | Moto G6 Android
08-21-2018 02:39
08-21-2018 02:39
We don't yet know for sure. Although one of the hands on reviews states the following
"Swipe left to see apps like Alarms, Exercise, Timer, Weather and Calendar, and swipe down to see your notifications."
Now whether that means Stopwatch, timer or both, we really can't say at this point. I would say it sounds promising though.
09-29-2018 05:09
09-29-2018 05:09
11-06-2018 09:59
11-06-2018 09:59
There is a countdown timer that worked fine until it didn't. Now it doesn't notify me when it hits zero which makes it useless!
Best Answer12-27-2018 00:56
12-27-2018 00:56
I can confirm that it has both timer and stopwatch. So far, both have worked fine 🙂
Best Answer02-06-2019 08:41
02-06-2019 08:41
Thanks, could not find how to see stopwatch.... even in the manual it does not tell you to swipe left.
Best Answer02-06-2019 16:12
02-06-2019 16:12
@DKUBISKE @SteveH @WendyB @N8teGee @SunsetRunner @BrianBJ @Tonithetiger Thanks for visiting the Fitbit Community.
I'm glad to hear that you figured out how to find the countdown timer on the Fitbit Charge 3. You can find instructions to navigate through your Tracker's screen on this help article.
If you have any question, please don't hesitate to contact us back.
Best Answer10-01-2019 07:24
10-01-2019 07:24
Does always on feature function during timer or countdown?
Best Answer10-01-2019 07:56
10-01-2019 07:56
Best Answer10-01-2019 09:26
10-01-2019 09:26
Is there an always on feature with this that allows you to constantly visualize the countdowns while event is taking place or do you have to keep tapping the screen
Best Answer10-01-2019 13:15
10-01-2019 13:15
Best Answer10-01-2019 15:18
10-01-2019 15:18
@capers12 Welcome to the Fitbit Community.
Currently, like @Tonithetiger mentioned, after 4 seconds of activating the countdown, the display will go blank and it will be necessary touching the screen to see the time running.
You are welcome to make a request on the Feature Suggestion board which is constantly monitored by our team for future implementations.
Feel free to contact us back at any time.
10-01-2019 17:12
10-01-2019 17:12
03-02-2020 09:56
03-02-2020 09:56
I had that same question.
