01-03-2016
05:03
20:42
01-03-2016
05:03
20:42
01-03-2016 05:44
01-03-2016 05:44
01-03-2016 05:17
01-03-2016 05:17
Sorry I can't help you. I'm also having the same issue. My battery died on the first, and since then, I've had to restart my HR, and while it shows that it has synched, the time is also off. If I discover something, I'll post.
Best Answer01-03-2016 05:39
01-03-2016 05:39
At least your not alone my tracker is also displaying data from last evening, I have restarted it with no results. Good luck. If i find a way I will post here. Happy New Year!
Best Answer01-03-2016 05:44
01-03-2016 05:44
01-03-2016 12:41
01-03-2016 12:41
I'm not sure how, but I left my Fitbit alone for a few hours, looked at it about 15 minutes ago and the date/time are current.
Best Answer01-04-2016 19:50
01-04-2016 19:50
Mine is doing the same thing- wrong date wrong time, and no data. Any ideas?
Best Answer01-06-2016 02:25
01-06-2016 02:25
I tried everything marked as a solution in other threads and the one thing I didn't see listed that actually worked out for me was to remove my fitbit from my account and then add it back. I lost most of the data I'm sure was collected during the "down time"/wrong date and time but now it's fully functional. Good luck!
02-02-2016 19:40
02-02-2016 19:40
Best Answer04-04-2016 09:53
04-04-2016 09:53
I have tried a few things, wrong date has been showing for a while now. I don;t use bluetooth for much and had it turned off on my phone, once i turned it back on, the date resolved on my fitbit charge.
Best Answer06-07-2016 14:40
06-07-2016 14:40
My time is wrong, nothing seems to help and Fit bit support won't answer me, my last Fitbit the strap came apart and stopped telling correct time...this is a replacment and it kept time for a couple weeks, now the time is off again, I've tried everything...please anyone help!
Best Answer12-16-2016 07:59
12-16-2016 07:59
wrong date and time/ lost a day (recharged- then the time and date was incorrect) Will it auto adj?
Best Answer12-19-2016 11:50
12-19-2016 11:50
How are you doing @tasha1612? Welcome aboard! First I recommend checking that your timezone settings are correct. If they need to be changed, please do so and then sync your tracker so that changes can be applied immediately. Take a look at this screenshot:
Good luck and hope this helps!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
Best Answer03-24-2019 19:21
03-24-2019 19:21
How do I reset time it is 1hour & 15 min fast
Thanks
Thanks
Best Answer03-24-2019 19:41
03-24-2019 19:41
