01-14-2016
10:48
20:15
01-14-2016
10:48
20:15
So 2 days ago I was at my parents and my fitbit died, I couldnt charge it because I didnt have the charger. When I got home I put it on the charger. It finished charging around mid night but the time on it said 9:35. Ever since then Ive had trouble with it syncing and the time still hasnt changed. What do I do to fix this?
01-15-2016 07:53
01-15-2016 07:53
Welcome to the Fitbit Forums @keamarti! I'd definitely start by restarting your tracker. If the issue persists, check out this sync troubleshoot article. Sometimes your tracker needs to bet set as a new device to fix the sync and time issues. You can also use these instructions to bring the time to normal.
I hope this helps. Let me know the outcome.
Best Answer03-28-2020 06:24
03-28-2020 06:24
Same- have you figured out how to reset?
