11-14-2019
08:19
11:53
11-14-2019
08:19
11:53
My Fitbit is syncing correctly on everything but the time. Now that we are on the East Coast it is one hour off even though we moved from the West Coast where there was a three hour difference. Does anyone know where I can adjust the clock setting ?
11-14-2019 12:59
11-14-2019 12:59
You select the proper Time Zone at Fitbit.com Settings. After adjustment, scroll on down and click Submit and then sync your tracker.
Best Answer11-14-2019 12:59
11-14-2019 12:59
Best Answer11-14-2019 13:40
11-14-2019 13:40
Best Answer01-25-2020 22:11
01-25-2020 22:11
Thanks for the tip it worked on fixing the time issue. Just wish I saw this before I tossed my old one and got a new one today. Which had the same problem as my old one 😒
