10-19-2018
23:30
18:22
10-19-2018
23:30
18:22
Been for a long time using the charge 2 on my left wrist, set for left wrist in the app, but due to various reason I'll have to switch to right wrist instead. So I changed to right wrist in the app, synced up with the charge so it could adjust the orientation as it said it will in the app, however nothing happened when I activated the display.
I checked the online dashboard and I could see it also changed wrist as I changed it on the app.
Tried syncing, change back and forth several times, yet no changes to the orientation.
10-20-2018 01:45
10-20-2018 01:45
I thought the screen orientation change only applied to the alta and alta HR. For the Charge 2 the button is always on the left regardless of what hand you wear it on.
Best Answer10-20-2018 02:58
10-20-2018 02:58
I thought so too after reading up on several other posts, older posts though.
However inside the app I can choose which wrist I have the charge 2 on and it says "Fitbit Charge 2 adjust its orientation based on which wrist you wear it on."
08-19-2019 17:16
08-19-2019 17:16
I changed mine during the initial setup to right hand. Attempts to adjust it after months of use to the left hand is not effective.
