07-11-2017
19:39
09:26
07-11-2017
19:39
09:26
when i walk with the google fit app enabled on my android device and my fitbit charge 2, the google fit app will reflect that I have walked 2.5 miles at an average pace of 16.30 minutes per mile. My fitbit charge 2 wiill reflect 2.1 miles at a pace of 17.45 minutes per mile. same walk, same GPS chip, fitbit charge 2 in walk mode, both enabled and stopped at the same time. how can there be such a huge discrepencay when the fitbit charge 2 allegedly uses the android GPS chip on the android device as does the android device? What does the fitbit charge 2 use the android GPS chip for other than producing a map? How can there be a discrepancy??? Obviously the fitbit charge 2 does not use the android device's GPS chip to log distance or pace. What am missing??
Hey hey hey @FITwalkerFIT! It is great to see new members around! 🙂 Let me explain to you that the Charge 2 and Google Fit app, both use different technologies to track your steps, distance, etc., so we don't suggest you to compare the data recorded by them. On the other side, because of the results that you posted, it looks like the difference still in the normal range. Regarding the GPS, I know that both apps use the same GPS signal on your Android phone, however the algorithms that the apps use are different, and that is why you don't get exactly the same results. I urge you to take a look at the information in this post about how the Fitbit track steps, so you can have an idea about how they work.
If you have further questions, let me know!
All the GPS unit does is send points when it has been requested to send them.
The apps are responsible for how frequently they request these points from the GPS chip, and what their own algorithms do with these points. So yes their individual algorithms, or what they do with the GPS data will affect the reported results.
I have also noticed that if i don't have enough free memory in my phone, the GPS suffers in the Fitbit app. Having a second power hungry app running has detrimental affects on the accuracy of my fitbit app.
Also if both apps tequest GPS data at the same time, one of the apps will get yhe data first. The other one will have to waiy, this wait will increase the time between points.
Best AnswerAs for as I know your Fitbit account can not be connected to Google fit, even if it could Fitbit would not be able to send a map of your walk to Google Fit.
Was your Fitbit map accurate?
As for the Google Fit map, this might be caused by using to mapping apps at the same time.
I did a hike yesterday and my Fitbit says I hiked 14 miles yet my Google Fit says 11. I'd love to know which one is more accurate. This hike had lots of switch backs and smaller steps since it was very rocky with lots of switchbacks as the hike has a 3100 ft elevation gain. My guess is the Google fit wasn't understanding all of the smaller movements to get up the mountain but would love to know! I have the Fitbit Charge 5
