09-29-2019
05:56
10:43
09-29-2019
05:56
10:43
the time on my fit bit is 2hrs fast
09-29-2019 07:12
09-29-2019 07:12
You can't manually set the time but it should reset itself whenever it syncs to your phone or computer based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the timezone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
Best Answer01-30-2020 01:24
01-30-2020 01:24
My time is to slow
