09-19-2017
06:57
09:26
09-19-2017
06:57
09:26
Hi,
I was trying to set up my interval training and i accidentally deleted the rest mode.
how do i get it back?? i dont want to move all the time and the intervals should be different.
also, can you add diffeent move times like 10 20 30 style?
thaaaaanks xoxo
09-25-2017 07:30
09-25-2017 07:30
Thanks for your reply @malenerosenkild!
I appreciate the clarification. Sounds pretty weird that the option just went off. Let me suggest you something, if you are using the Fitbit app, please log out and log back in, then check out if the option came back. Also, I'd like you to review your Fitbit account on your PC Dashboard, and let me know if the "rest" option is there. If so, please check it, sync your Charge 2 and review on the app if it appears there. If the option still missing, could you please post an screenshot of the interval mode feature so I can further investigate?
Thanks in advance!
09-19-2017 08:40
09-19-2017 08:40
Hey @malenerosenkild, it is nice t to see new faces around!
If you are using an Android device, please follow these steps to get back the rest on your interval workout:
- Tap the Account icon
- Tap on Charge 2
- Scroll down and tap on Exercise Shortcuts
- Tap on Exercise shortcuts
- Tap on Rest and you can set the time for resting
- Finally sync to save those changes
Now regarding your request, let me see if I understood it, so you'd like to have the option to set intervals with different duration, right? If so, you can go to our Feature Suggestions board and post your idea there so our developers can take a look at it and maybe take it into consideration in the future. ![]()
Let me know if you have further questions!
Best Answer09-21-2017 23:34
09-21-2017 23:34
maybe i did not ,make myself clear about this one but the rest mode button is GONE.
i deleted it and i cant get it back..
can somebody help???
Best Answer09-25-2017 07:30
09-25-2017 07:30
Thanks in advance!
09-26-2017 03:57
09-26-2017 03:57
thank you so much!
it worked when i went on my computer and checked the interval training and i could click rest back on!
awesome 😄
Best Answer09-26-2017 05:56
09-26-2017 05:56
Hi @malenerosenkild, I appreciate the update! Sounds pretty cool that the rest mode back on and you have that option available again. 🙂
If you have further questions, keep me posted!
Best Answer10-05-2017 01:35
10-05-2017 01:35
I have the same problem, I deleted my rest mode but I want it back. I followed your instructions, but rest mode is still gone.
Please help!
Best Answer10-06-2017 07:21
10-06-2017 07:21
Best Answer10-06-2017 10:47
10-06-2017 10:47
I've started from the beginning and I have solved the problem. The rest mode is back and I just had an interval workout. Thank you for the advice and quick response!
Best Answer10-09-2017 05:49
01-22-2018 21:21
01-22-2018 21:21
@HeydyF wrote:Thanks for your reply @malenerosenkild!
Thanks in advance!
Heydy, reading your responses is kind of infuriating because you ignored her actual issue and just called it "strange".
It's not strange, it's a feature in the app. If you swipe left on the "rest" interval while editing the workout then it removes the rest and there is no way -within the app- to bring it back once removed. Very annoying.
01-21-2019 22:04
01-21-2019 22:04
So this is still happening in the app 2 years later....
I cannot see "rest" on my dashboard. Where EXACTLY is it in the dashboard.
I've tried logging out and back into the app and this hasn't fixed this PROBLEM (not strange occurrence that is still happening 2 years on)
