09-25-2019
13:43
19:49
09-25-2019
13:43
19:49
the old one was broken so i bought a new one. how do i get this new one into my app and how do i get the correct time into my new tracker?
09-25-2019 14:24
09-25-2019 14:24
@djeanny - If your old device is still attached to your account, you must remove it by tapping Account - Alta HR —> Remove. Check the Bluetooth in your phone’s settings and if the old Alta HR is listed, give the command to Forget This Device.
Once that is done, you can follow the directions in my previous post to attach the new Alta HR. Once it is attached and synced to your account, it should show the correct date and time.
09-25-2019 14:15
09-25-2019 14:15
Hi @djeanny - Congratulations on your new Alta HR! Here are the steps to follow to add it to your account:
Please let us know if you need any more help than this. If you do, let us know which phone you have and which version OS the phone has.
09-25-2019 14:19
09-25-2019 14:19
because of the broken one i have already the app on my phone. how can i connect the new one to it? and how can i change the time on the tracker to the real time (its a used one)?
Best Answer09-25-2019 14:24
09-25-2019 14:24
09-25-2019 15:28
09-25-2019 15:28
thank you - got it! 😍
