04-21-2022
21:56
14:29
04-21-2022
21:56
14:29
Have just been for a ride ,synced when i got back after a while, only shows ride from 2 days ago, not todays. any ideas please
@Royalstar , Nice to see you back. Thank you for your message .
How do you record your biking tours? Do you start it on the Charge 4 or you let it autorecognize it?
Do you have MobileTrack active?
See you around
@Royalstar , Thank you for your reply!
There can be various reasons why your activities were not recorded or recognized correctly.
For example, the activity is not fully recognized by your movement patterns.
You paused for more than 30 seconds during the first few minutes, so the tracker might "think" the exercise was over.
I recommend restarting your tracker and setting the start times for the activities differently. For example, set it to 10 minutes for a walk, 15 for a run, 20 for an outdoor bike ride, etc., and/or ignoring the activities you don't use.
You can find the instructions for this here.
Can I change how my activities are tracked?
You can verify if you have MobileTrack active by tapping on your profile picture on the Fitbit app.
If you see it listed tap on it and then on the trashcan to remove the feature.
Hope it helps.
