10-29-2022
09:36
13:05
10-29-2022
09:36
13:05
I cannot find the brightness button and it seems that everything is mixed up on my watch. Is there a way I can delete everything on it and start fresh?
10-29-2022 09:41
10-29-2022 09:41
Hi @LARCOL page 18 of the user manual tells about changing the brightness. click to read the manual. See if that helps before doing the factory reset, which is more work. You'd need to remove it from your account, clear the device and then set it up again. directions here - click
