02-03-2020 09:08
02-03-2020 09:08
I am very confused on how to add exercises that are not on the option list, how do I that and re-name an exercise label? I have tried doing this on my Inspire HR app and on the dashboard but I don't know how to do that. Please clarify this for me.
Best Answer02-04-2020 00:30
02-04-2020 00:30
Hi @B3 This does seem to be a bit confusing. Firstly, you cant change the exercises the tracker automatically recognises. But you can change the exercise shortcuts on the tracker to manually start amd stop an activity, to any on the list. To find the list, in your app go to your account (icon/avatar in the top left corner) and select Inspire HR off the devices list. The scroll down on the Inspire HR page to Exercise shortcuts. If you have the full quota on your Inspire HR you will have to delete one befpre the plus sign appears in the top right corner of the screen. Tap the plus and you can add shortcuts there. If the activity you want to recognise is not listed, then add the 'Workout' shortcut and use that. After you have recorded a workout you can rename that activity session in the app afterwards, but you have to do this each time you do the activity. There is no way to permantly change the name. Good luck!
Helen | Western Australia
