04-03-2019 16:28
04-03-2019 16:28
I have All Day Sync turned on. However it seems that the only time my fitbit seems to sync is when I open the app. For example today I last opened the app around 1.35pm. When I looked through the web dashboard tomight at 7.15pm it showed that the last sync was 1.35pm. This does not seem to be All Day Sync'ing ! Anyone actually see it sync all day.
Best Answer04-03-2019 17:33
04-03-2019 17:33
@gfbuyer If you haven't already, try to perform these actions and see if they help:
Best Answer04-03-2019 17:20
04-03-2019 17:20
@gfbuyer Welcome! Can you provide details about which phone and operating system you're using? Have you performed a restart on your Inspire?
04-03-2019 17:33
Best Answer04-04-2019 03:10
04-04-2019 03:10
I have an iPhone 8 on 11.4. I have restarted the phone and also restarted the fitbit.
Best Answer05-30-2019 10:56
05-30-2019 10:56
I have had a lot of problems with my Alta HR and all day sync. In fact, my device was replaced earlier this year because of this issue. Now my replacement isn’t synching at all, only several months after receiving it.
And YES I have turned Bluetooth off, then on. Deleted Fitbit from device and reinstalled. Forced a sync with charging port. All of the above, more than once. I have even totally deleted the Fitbit app then reinstalled. This is getting very frustrating.
The original issue was that that my heart rate did not show on the display, although the number of steps changed. Now the number of steps does not update AND my heart rate only shows resting bpm.
And before you ask, I have used Fitbit Alta HR for over a year. The strap is in good shape. The Fitbit is in the proper position on my wrist. Nothing has changed.
There is obviously a major bug in the all day sync program. Please fix it.
09-14-2019 07:14
09-14-2019 07:14
I am having the same issue.
Best Answer01-08-2020 13:52
01-08-2020 13:52
I tried all that. I even switched over to a different iOS device but still not working.
03-07-2020 05:48
03-07-2020 05:48
I am also frustrated with this, cancelled buying two other devices for family members. Thinking to return mine
03-07-2020 19:33
03-07-2020 19:33
None of them works. It’s fitbit, not us.
It’s been going on for months and months it’s so annoying!!!
03-14-2020 18:27
03-14-2020 18:27
Im in the same boat along with my husband. I have an iPhone xs and he has an iPhone 6. Sometimes I can go 18 hrs before I have to physically sync it. We have challenges with friends and often we forget to go into the app and sync so our steps don't count as we missed cut off. This has been happening for months and its quite annoying. I have done all the steps suggested to no avail. It must be something going on with Fitbit...I hope that they fix it soon.
Best Answer03-14-2020 18:28
03-14-2020 18:28
This hasn't helped in the slightest...any other suggestions?
