06-17-2019 09:45
06-17-2019 09:45
My Bluetooth was working fine on my inspire for about 5 days then all of a sudden it stopped working. I cannot get the inspire to come up on my iPhone Bluetooth page and I am not getting any notifications on my Fitbit from my phone. However, if I go to the Fitbit app, my steps and other info will sink up to my phone. How do I get my Bluetooth to start working again?
I tried turning off my phone, letting my Fitbit die and charging it, turning on and off my Bluetooth on my phone but none of that worked.
06-17-2019 09:50
06-17-2019 09:50
Hi @Mkp24 Welcome to the forum. I'm sorry you are having an issue with your Inspire. I've had the same thing happen a couple of time. What works for me is to go to the Bluetooth settings on my iPhone, select the connection to you Fitbit and then select "forget device". Excite out of the setting, then go back in to make sure you are no longer connected via Bluetooth. Then go to the Fitbit app and go to the notifications setting. Now you should get a pop us saying you need to set up Bluetooth. Let you're phone reconnect to your Fitbit and your issue should be resolved. Fingers crossed it works for you.
Best Answer07-19-2019 13:15
07-19-2019 13:15
this worked for me on an Android phone.
