09-15-2022
12:35
21:04
09-15-2022
12:35
21:04
How do I update the time?
09-16-2022 01:29
09-16-2022 01:29
You can't manually set the time, but it should reset itself whenever it syncs to your phone based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the time zone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
