Connected GPS Running
This started popping up on my Galaxy S6 phone and would not go away. There were several options listed in the forums as to correct it, but nothing worked. I finally turned off persistent notifications and that seems to have done the trick. It does not seem like I will get notifications, but the battery drain is ridiculous. I left on the all-day sync, so we'll see how it goes. I like everything else about the Inspire HR, so we will see how this works out.  **update** Well, that didn't work. I turned off the sync. I will just sync it every day or so and see how that works. I hope they figure out how to fix this bug.
2 REPLIES 2
Hey @Brooknm , a warm welcome to the Community ! Thank you for your post and the steps performed.  Could you please confirm the message that you are receiving? If possible, could you attach a picture of it on your answer? Please attach it directly to the reply and not on any Cloud service.
Regarding to the battery situation, have you read the tips on this article?
I'll be expecting your reply.
Hi, Julie!
Yes, I had most notifications turned off. The GPS running started a few days ago. Previously, there had been a message that the Fitbit Sync Service was active, but this was replaced by the Connected GPS Running. At this time, I've deleted the app entirely. I decided I'd just download the app, sync, and then delete it again, at least until some sort of fix can happen. If it can happen.
