03-19-2019 17:02
03-19-2019 17:02
I'm having trouble with getting the GPS to turn off. I have went on the physical Fitbit website and turned it off from there and disabled the always connect option on the app but i still have the notification stating connected gps is running ( going on 6 hrs) my phone battery is draining from this ..i have an Android phone and the fitbit inspire hr if that helps. Any suggestions would be helpful .
Best Answer03-19-2019 20:26 - edited 03-19-2019 20:27
Welcome to the forums!
Not knowing what GPS you re using All the ones I have to have to stop it on the Phone when done. Are you doing that? Need to also push in the button on the device
Let us know
Wendy | CA | Moto G6 Android
03-20-2019 05:24
03-20-2019 05:24
I ended up repairing the fitbit to app then restarted the phone ..that fixed the problem. Thank you
07-21-2020 06:33
07-21-2020 06:33
mine does the same thing. Have to turn off location every day and then turn it back on long enough to sync. drives me crazy
