Does anyone know if two seperate Fitbit HR will connect to the same device. I have my own connected to my phone and I want to get my dad one and don’t know if his phone is compatible (he has a nokia Android) so would it be possible to connect two Fitbits to my phone ? Thanks
It would be very messy as you would have to keep logging out of one account and signing in to the other to sync and view the two dashboards.
You can check to see if his nokia is supported at www.fitbit.com/devices
Best AnswerThankyou! His device doesn’t come up but it does say if the phone follows the android requirements it should work so hopefully it does
