06-17-2019 19:07
06-17-2019 19:07
When I set my countdown for 20 min (or any other time) it will count down but it won't buzz to let me know that it's done. Also once it is done counting down from 20 it starts counting down from 59 min automatically.
I really need this to work so that I can ref soccer games and keep the time.
06-18-2019 11:59
06-18-2019 11:59
Nice to see that you're digging into the Forums @ethurn2010, let me give you a warm welcome to our Community. ![]()
Thanks for reporting the issues with the countdown timer of your Inspire. Please try to restart it with the following steps:
Your tracker should now work normally. Please confirm if it is buzzing with other features like notifications or alarms. And if your tracker still doesn't work after a restart please let me know.
I'll be around.
Best Answer06-20-2019 05:34
06-20-2019 05:34
I'm having the same problem. I tried restarting like you suggested, but it didn't fix the problem.
I'm setting it for a minute and it just keeps going.
08-26-2019 04:27
08-26-2019 04:27
Hello,
I am having the same problem as well. My countdown timer does not vibrate once it is finished counting down. I only now realized that this was a feature.
I have restarted my FitBit on two separate occasions and it has not resolved the issue. In fact, I wasn’t aware it was supposed to vibrate at the end of the countdown as it has never done so since I purchased it in May.
Do you have any other suggestions?
Any help is appreciated.
08-26-2019 09:01
08-26-2019 09:01
I have exactly this same problem, I have also tried the reset but with no success- any help would be appreciated
08-26-2019 09:07
08-26-2019 09:07
Same problem here, I think it's vibrating, just can't feel it. If I hold the watch with my other hand, I can feel it vibrate (with that hand, but not on my wrist).
Best Answer09-08-2019 07:13
09-08-2019 07:13
Did anyone find a solution to this? I just got my Fitbit yesterday and I’m having the same issue.
Best Answer09-28-2019 20:55
09-28-2019 20:55
I figured it out ! I was having the same problem. So when you are trying to set the countdown you have to make sure you scroll down to 00hr then tap once again and the screen changes to 00 mins after you can scroll down to how many ever minutes you wanna set it for and then tap to set it. You’ll notice usually on the screen if you have set it for say 2:00 mins in the screen background above it’s shows 00: instead of 59: so basically you have set it for 2:00 instead of 59 hrs and 2 mins I don’t know if this is making any sense but it works let me know if it did for you.
12-01-2019 19:03
12-01-2019 19:03
Yes, it worked! I don’t think the Fitbit technicians know this one as this is my third one! Thank you!
07-10-2020 03:15
07-10-2020 03:15
Thanks 🙏
Best Answer03-11-2021 09:17
03-11-2021 09:17
Thanks. The vibration is too soft to notice. It should be the same intensity as the alarm vibration.
Best Answer06-12-2021 00:05
06-12-2021 00:05
Numbers not showing so can't be set
Best Answer11-02-2021 05:12
11-02-2021 05:12
Same problem but i have got the solution
Pls keep your hrs 00 when setting into minutes in inspire. 🙏🙏
