Error in Active Zone Min section
Hello.  My Active Zone minutes for Saturday shows 42 minutes.  I went swimming, so I did exercise.  But it also says "2 minutes in heart rate zones," and the graphic under "Active Zone Min" clearly shows heart rate barely into the moderate zone. ^1
This does not add up at all.  How do they get from "two minutes" to "42 minutes?"
Thank you, Alex
^1  Also in a separate section under "Heart," similar graphic.  And thirdly, altho I was swimming 32 minutes in real life, but plausible that it was low / moderate intensity
Moderator edit: formatting
1 REPLY 1
Active Zone Minutes are usually calculated based on the intensity of the exercise.  Your heart rate needs to be above a certain BPM for it to count.
Can you send a screenshot of what you see on the phone app?
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
