07-31-2019 03:28
07-31-2019 03:28
Can you get an exact fitness score with this fit bit as I am only getting an Range despite logging my running? X
Best Answer07-31-2019 07:18
07-31-2019 07:18
According to the help file on this (see: https://help.fitbit.com/articles/en_US/Help_article/2096/ ) you need to track your runs using GPS to avoid getting a range. Was this how you logged your runs?
Best Answer07-31-2019 08:11 - edited 08-01-2019 08:34
Is it possible to see your exact fitness score with decimals?
(Fitbit charge 3, running with gps)
Best Answer07-31-2019 14:14
07-31-2019 14:14
Yes I did, I used to have a charge 2 and it worked perfectly with that model but with the inspire hr it seems stuck on a range 😞
Best Answer12-23-2019 03:59
12-23-2019 03:59
I have the same issue with Inspire HR, I always see an interval and never saw a fixed number. My husband has a Charge 3 and he got a fixed number after his first GPS run.
I've tracked over 10 runs with GPS, each at least 20min long. I've been using an iPhone 7 for the GPS tracking.
@CJMacf did you get it resolved?
Best Answer12-23-2019 05:03
12-23-2019 05:03
02-03-2020 09:33
02-03-2020 09:33
I made this same switch too, from a Charge 2 to an Inspire HR - because I wanted something smaller and waterproof. I had an exact fitness score for more than 12 months with my Charge 2 but since I switched to the Inspire I only get a range - and even though I run at least once per week using GPS and have done for months now, I cannot get a specific score.
Has anyone with an Inspire HR got an exact fitness score???
Best Answer02-03-2020 12:37
02-03-2020 12:37
Best Answer02-05-2020 03:14
02-05-2020 03:14
I mailed Fitbit support and unfortunately got a copy and paste reply about doing all the things I explained to them in my original email that I already do. Very disappointing.
At this point I really just want to know if anyone with an Inspire HR has a specific Cardio Fitness score or not.
