05-19-2020 01:46
05-19-2020 01:46
In the last few weeks, fitbit has started recording my exercise multiple times (pic attached), particularly walks. I use the tracker on the app, never use exercise tracking on the fitbit itself as I find it really poor to use. I'm not sure if its automatically recognising exercise (even though I'm tracking), it doesn't say it is.
If I delete one, they all vanish and I lose all exercise! Any help gratefully received!
Best Answer05-19-2020 08:26 - edited 05-19-2020 08:30
I would delete the ones without the map, they should have been removed automatically when you used the Fitbit app. Others have reported this, so it must be a problem with a recent update.
You may want to turn this auto detection off.
