06-01-2020 23:57
06-01-2020 23:57
Hi I have searched this but the only responses have been to restart which I have tried several times and it hasn't worked, my exercise option shows run then Pilates for all the other options, can anyone suggest a fix it do I need to ring and get it try and sync or with options not working, it has only given me notifications a few times in the couple of months I've had it as well. Thanks in advance
Best Answer06-02-2020 00:33
06-02-2020 00:33
I have exactly the same issue for a few days now. No syncing helps and set up also does not work as it says ''Something went wrong''. Help, please and thanks in advance.
Best Answer06-02-2020 03:50
06-02-2020 03:50
My hr inspire is the same wont let me swipe up to track my runs have googled it and nothing is helping me
Best Answer06-02-2020 05:11
06-02-2020 05:11
It's so frustrating isn't it, have you tried the live chat option, mine isn't working
Best Answer06-02-2020 05:17
06-02-2020 05:17
Best Answer06-06-2020 02:50
06-06-2020 02:50
Mine just randomly corrected itself a few days after this, really not impressed with the reliability of these I certainly wouldnt be recommending them to anyone
