09-11-2019 08:40
09-11-2019 08:40
My wife has the Fit Bit Inspire HR and something strange started happening. Prior to about a week ago, the activities that were listed in the Iphone App matched what was shown on the phone. (i.e. running, cycling, swimming, etc). Now, the phone app shows the correct list of activities, however the fit bit device only shows Pilates. And it shows it multiple times. It does seem to be syncing the number of steps that she takes and the hourly steps so the fit bit is syncing some things correctly, however the activities are not syncing correctly.
We've tried restarting the fitbit, we tried forcing a sync. I've checked and the fit bit has the latest firmware. The app is also up to date. Has anyone else seen this issue and if so, did you find a solution to get things back on track?
09-11-2019 08:48
09-11-2019 08:48
That has been happening with Inspires, guessing side-effect of an update.
I think I solved it on mine by going back to editing exercises in the Exercise app, though I don't remember exactly if I just edited them or had to delete all add re-add them.
See How do I change or reorder the exercises in the Exercise app?
