08-04-2023
12:54
12:02
RodrigoMFitbit
08-04-2023
12:54
12:02
RodrigoMFitbit
Sync stopped, device won't wake up.
08-04-2023 16:52
08-04-2023 16:52
Hello @susantutu
Sorry to see you're having problems with your Inspire 2.
The first troubleshooting step to try is to restart your Fitbit.
If Inspire 2 is unresponsive:
Best Answer08-04-2023 17:01
08-04-2023 17:01
08-06-2023 11:46
08-06-2023 11:46
I'm having the same problem and nothing seems to fix it 😕 It was fine until 2 days ago. Not only is it not syncing, but the screen is hard to read, very dim, not brightness at all. Very frustrating for me!!
Best Answer08-07-2023 11:34
08-07-2023 11:34
This sounds like a similar problem that the Charge 5 is having (go to that community if you can handle a scare.) I am going to be very disappointed if the same update that crashed my 5 also crashes my 2. I charges my 2 this morning and notice that the charge seems to be running down very quickly.
08-07-2023 14:14
08-07-2023 14:14
I am having the same issue today, yesterday it worked fine. Screen and side buttons are non responsive. I tried restarting it by following the steps above and nothing happened. It seems to be syncing to my app and charging fine, but the screen and buttons are frozen. Please help!!
08-09-2023 21:15
08-09-2023 21:15
Same here- plus the green light is gone and although the battery is charged and current battery level is showing when I sync with the app, none of my steps or zone minutes are syncing. Very frustrating and disappointing!
08-16-2023 15:15
08-16-2023 15:15
Same here! Whenever I plug it in the charger I reset it and the smiley appears, but after I take it from the charger everything is umresponsive
Best Answer08-17-2023 08:56
08-17-2023 08:56
Good to see you around the community everyone.
Welcome to the forums @Actingbug27 @ingesmit
Thanks to all for sharing the inquiry regarding the situation with your trackers.
I've been informed that some of you already contacted the Customer Support team for further assistance with this. In this case, they will let you know how to proceed.
If this is related to the battery, please make sure that you've followed the steps provided in this article: Why isn't my Fitbit device's battery charging?
If the device is charging, but the screen is completely black, make sure that you've also completed the restart procedure as suggested by @RiekoC.
Please, change the clock face following these steps:
