01-22-2021
18:53
06:11
JuanJoFitbit
01-22-2021
18:53
06:11
JuanJoFitbit
I am trying to add Inspire to my account that has already got an Aria attached. I am using my laptop on Windows 10. After following instructions the device after charging only shows the Fitbit logo with the fitbit.com/setup. My laptop is aware of the device and will sync to it but I can get no icons or other movement from the device itself. I am awaiting response from support but so far all they have offered is to connect to another device, an android one. I just want to use the device the same way the Alta does using my laptop.
Thanks for your reply but I already have 2 other devices on my account. I have circumvented my problem by setting up on an android device. That works, it seems set up on windows does not work.
