10-21-2020 05:12
10-21-2020 05:12
My Fitbit Inspire is not tracking my sleep. I've tried restarting it and redownloading the app and it's still not working...
10-21-2020 05:16
10-21-2020 05:16
Did you try manually syncing your device through the app?
Best Answer10-21-2020 05:25
10-21-2020 05:25
Best Answer10-22-2020 06:08
10-22-2020 06:08
I discovered that mine was set to clip and not wrist. I will see if this helps tonight and report back. Hold button down until the battery screen pops up. Then scroll to bottom and choose wrist.
Best Answer10-22-2020 08:57
10-22-2020 08:57
Is this only for the Inspire? I have an Inspire HR and do not have the wrist/clip option when I press down until the battery screen pops up. I have a light bulb and notification and that is it. Thank you!
Best Answer10-23-2020 04:27
10-23-2020 04:27
