On my iOS - Location, it is set to "Always." I had the phone with me when Fitbit exercise was set to walk. I do not see the GPS route map in either the app on the phone, or in My Dashboard on the computer. The last time a route map was shown on my phone was 4/25. Has something changed since?
Best AnswerHi, @SunsetRunner , if you want to see the route map at the end of your walk, you will either need to start it manually in the app: on the app go to the exercise tile and at the top of the next screen click on the stop watch icon and choose “track”. Don’t forget to stop when you are done!
Alternatively you can control this entirely from your wrist using “connected GPS” on your Inspire HR. Here are the steps to do that:
1. Turn on Bluetooth and GPS on your phone.
2. Make sure the Fitbit app has permission to use GPS or location services.
3. Make sure connected GPS is enabled on Inspire HR (open the Settings app >
Phone GPS).
4. Follow the steps below to track an exercise. Keep your phone with you during
the workout.
To track an exercise:
1. On your tracker, open the Exercise app .
2. Swipe to find an exercise, and tap to choose it.
3. Tap the play icon to begin the exercise, or swipe up to set a goal for time, distance, or calories, depending on the activity.
4. When you're done with your workout or want to pause, press the button. (Press the button again and tap Finish to end the workout.)
5. Swipe up to see your workout summary.
6. Press the button to close the summary screen.
This is not a change. If you are following these steps and still not seeing a map, it may be that “connected GPS” did not ever properly connect, so the map was not tracked. This does sometimes happen. You should get a notice on your wrist when the GPS is connected.
I hope this helps!
