Gps
How do I turn on gps when running. I noticed if I start a run on my phone it gives me a map of my route but if I start it with the inspire screen I do not get a map of my route can I change this or do I have to use my phone if I want a map.
1 REPLY 1
Hi @Miles.s , thank you for your question about the GPS use with your Inspire HR.
You are on the right way .If you start your record on the Fitbit app (MobileRun), it will show you the map and the information recorded by your phone.
You need to connect your tracker to your phone to use Connected GPS, so that the information is taken of your watch and the GPS data from your phone.
If you haven't done so, please have a look at this:
Please keep in mind that the Fitbit app should be allow to run on the background, so that you don't loose connection with the tracker.
Let me know if you have further questions.
