03-11-2019 15:43
03-11-2019 15:43
Have been wearing an Inspire HR for several days and everything was working great. It wasn’t counting my steps on the treadmill, so I attached it to my shoe—which I used to need to do with my Flex—well, after putting it back on my wrist, the heart rate is blank. Everything else is working, and the heart rate blinking light on the back is working. Any ideas?
Best Answer03-11-2019 16:14
03-11-2019 16:14
@kjossi46 Not sure if this is your situation, but it happened to me and this was the fix:
If the heart rate setting is "ON", then you may need to reboot your tracker (it won't erase data).
03-11-2019 16:14
03-11-2019 16:14
03-11-2019 16:37
03-11-2019 16:37
Thank you, that’s exactly what was the problem. Didn’t know I had turned it off.
Best Answer06-30-2019 07:00
06-30-2019 07:00
Yep, worked for me too. (Who is that person who mysteriously turns things off?)
Best Answer07-18-2019 20:27
07-18-2019 20:27
Hi, I have followed all the steps and still my heart rate is - -
1. It’s turned on in Settings
2. Rebooted with smiley face
3. Still no heart rate
Any other suggestions?
08-12-2019 12:43
08-12-2019 12:43
Like KSKing, my heart rate is on, I have rebooted, all my my exercise and steps are tracking fine, but my heart rate is not working. For me, it's important, because I can't use the sensitive sleep tracking without the heart rate, and I have some medical issues that require the more sensitive data (the non-sensitive data shows that I only get 2-4 hours of sleep at night.)
Best Answer08-14-2019 12:28
08-14-2019 12:28
Thank you so much!! I kept trying to turn the heart rate back on through the app and was having no luck! You made my day!
Best Answer08-14-2019 14:09
08-14-2019 14:09
What finally worked for me was restarting my iPad, which still seems weird to me, since other things besides heart rate were working.
Best Answer10-07-2020 15:59
10-07-2020 15:59
Mine is doing the same thing. Did you get yours fixed yet?
Best Answer10-07-2020 17:51
10-07-2020 17:51
Best Answer11-01-2020 07:28
11-01-2020 07:28
Check that the FitBit is in 'wrist mode' and not 'clip mode' in the settings. Clip mode was the default for me and Heart Rate was not showing as an option. I switched to wrist mode, switched Heart Rate as 'on', rebooted the device and now tracks heart rate BPM.
