How do I setup my Inspire?
I used to have the Fitbit Blaze, but I just purchased the Fitbit Inspire. I cant seem to connect my new Fitbit Inspire, I only see the Blaze info. How can I connect my new device on my old profile?
2 REPLIES 2
How do I set up a replacement device or add a second device to my account?
Follow these instructions if you already have a Fitbit account and want to replace your existing Fitbit device with a new one, or if you use more than one device connected to the same account. If you’re replacing one device with another of the same model, you’ll be asked to confirm the replacement. For instructions on how to remove a Fitbit device from your account, see How do I remove a Fitbit device from my account?
Choose a link below depending on whether you prefer to use the Fitbit app or Fitbit Connect to set up your device.
Fitbit App
  1. Tap the Today tabJohnnyRow_0-1573750834261.png, and tap your profile picture.
  2. Tap Set Up a Device.
  3. Choose your device and follow the on-screen instructions to continue.
Welcome to the Community, @PB.NYC and @JohnnyRow, thanks for the input.
I was able to see here that our friend @JohnnyRow provided some instructions in order to fix this setup issue. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
