01-06-2021
16:00
15:06
SilviaFitbit
01-06-2021
16:00
15:06
SilviaFitbit
how do I move the clasp on the mesh band for adjust the size for my wrist?
Best Answer04-17-2022 19:58
04-17-2022 19:58
I like the metal mesh band. It was a free addin when I bought it and didn't expect much, but it's great.
Yes, there is a hinged lever that locks/unlocks the band....a tiny screwdriver works perfect,
Best Answer04-17-2022 20:05
04-17-2022 20:05
You have the Luxe?
19:55
09:38
ManuFitbit
04-20-2022
19:55
09:38
ManuFitbit
No, I have an Inspire 2 with an Inspire 2 Stainless Steel Mesh. Sorry I might have misled you if the "Luxe" is a different clasp.
Hey, I just realized I posted this in the "Inspire 2" forum...so I did have it right. 🙂
Best Answer07-13-2022 16:07
07-13-2022 16:07
Just received mesh band for luxe. I too never got it opened but I followed the above suggestion of sliding the band. That worked!
Best Answer12-03-2022 14:20
12-03-2022 14:20
We have to do that every time we want to take it off and charge? Wow, that's not very user-friendly
Best Answer01-20-2023 18:16
01-20-2023 18:16
To adjust the band you don’t need to open the clasp. Close the band with the magnetic closure (not while wearing it), then gently pull on the band until you hear a little click. Be sure to pull in the direction you need (tighter or looser).
04-27-2023 17:43
04-27-2023 17:43
I still can't figure out how to adjust the clasp on the luxe stainless steel mesh band. I disconnected one strap from the other, but this image doesn't match what I'm seeing on the luxe clasp, and if I'm supposed to pry up part of the clasp with a screw driver, I need direction on which side to insert the screwdriver, so I don't break it.
Best Answer04-28-2023 00:18
04-28-2023 00:18
Just slide the clasp to a tighter position. Don’t pry it open. As you slide it, it will make a click sound at each new location.
10:17
09:13
04-29-2023
10:17
09:13
Welcome to the community forums @jbanksesq.
Thanks for your inquiry regarding how to adjust the band.
I suggest you visit here our website in order to have a better idea about how to wear the Stainless Steel Mesh.
It's nice to see you around @JH100a and thanks for your help.
Best Answer05-02-2023 21:42
05-02-2023 21:42
@JH100a - Thank you! I just purchased the fitbit Luxe with Lunar White Band, and the Luxe Stainless Steel Mesh band in soft gold.
To everyone inquiring about "how to size" the Luxe Stainless Steel Mesh band, please see JH100a's post. Saved me from prying open the clasp and destroying the band.
"To adjust the band you don’t need to open the clasp. Close the band with the magnetic closure (not while wearing it), then gently pull on the band until you hear a little click. Be sure to pull in the direction you need (tighter or looser)."
-nt
16:51
09:13
05-03-2023
16:51
09:13
Welcome to the community forums @NT14.
Thanks for the details regarding the Lux band and for advising.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Best Answer06-29-2023 06:08
06-29-2023 06:08
Thank you so much! This did the trick and was so easy. No need for screwdrivers or jewellery shops. I had to adjust a few times to get the right size. I would suggest Fitbit includes these instructions with the box the band comes in. I also agree that the amount of packaging is a bit excessive.
