How to customize workouts
ANSWERED
Hi does anyone know how you can add workouts you’ve done from the fit bit apps to favourites so you can find them easily again?
1 BEST ANSWER
Accepted Solutions
How to customize exercise modes
On the computer Dashboard go to settings. Scroll down to Exercise Shortcuts. Expand it and make changes to the exercises you do the most but make 1 Workout. Use workout mode for things that are not listed. You can rename it after it syncs
To add a custom activity On the computer Go to the Exercise tab and scroll to the bottom. You will see a link to add a custom exercise
Community Council Member
Wendy | CA | Moto G6 Android
1 REPLY 1
