12-23-2020
09:26
16:42
SilviaFitbit
12-23-2020
09:26
16:42
SilviaFitbit
I turned in running but can’t exit. Can someone please tell me how to do that? Thanks!
12-23-2020 09:29
12-23-2020 09:29
Turned on*
16:42
07:23
12-23-2020
16:42
07:23
@Dpang A warm welcome to the Fitbit Community.
To end the workout, press the buttons again and tap Finish. Swipe up to see to see the workout summary and press the buttons to close the summary screen.
Check out this post about Inspire 2 tips.
I'll be around if you have any additional questions.
Best Answer06-29-2021 21:10
06-29-2021 21:10
This tip does not work. My exercise continues on and won’t stop until I reset the whole darn thing!!!
When you say press buttons, you mean the two on opposite sides, right? When I press them the Fitbit kicks over to the water lok screen.
help???!!
07-01-2021
11:44
06:43
07-01-2021
11:44
06:43
@Dobrzyn Welcome to the Fitbit Community. Thanks for the restart performed prior to posting.
I see where your disappointment is coming from. To end a workout, press both buttons or the two opposite sides, then the "Finish" option should pop up to end the workout.
Please confirm you're doing this procedure to start and stop:
If you're still experiencing difficulties, get in touch with our Support team, they'll be happy to help.
Hope this helps.
09-23-2021 19:19
09-23-2021 19:19
It takes like 10 minutes to get it to actually do this. ☹️
09-24-2021
18:10
06:42
09-24-2021
18:10
06:42
@javamooney Welcome to the Fitbit Community.
I see where you're coming from. Let's try restarting your Inspire 2 and make sure its settings are properly set by checking this article.
Hope this helps.
08:40
09:09
BraulioFitbit
09-27-2021
08:40
09:09
BraulioFitbit
I accidentally turned on some kind of tracking exercise and it's been running for about 16plus hours. I have tried to turn it off and it's getting really annoying now. I just want my normal views back. I don't see the option described here to turn if off just a bunch of stats on the extended "exercise tracking". Please help.
Okey dokey. I found the article on how to restart the fitbit and like with most devices when all else fails: reboot.
Moderator Edit: Merged replies
16:58
06:42
10-01-2021
16:58
06:42
@uselessatFBtech Welcome to the Fitbit Community. Thanks for the details mentioned.
I see where your disappointment is coming from. I appreciate the restart performed.
May I know if your tracker is back on track? In the meantime, check out this article about getting started with Fitbit Inspire 2.
Have a nice day.
Best Answer10-05-2021 08:40
10-05-2021 08:40
This has happened to me and nothing I do can get rid of it. I’m not getting the Finish option. And when I try and stop it, it goes to the water lick screen and I can’t get out of it.
HELP
10-06-2021
14:45
06:42
10-06-2021
14:45
06:42
@JudeRoos Welcome to the Fitbit Community. Thanks for the details mentioned.
I see where you're coming from. Let's try restarting your Inspire 2 and make sure you're following this procedure to stop the activity. After this, continue monitoring its functionality.
Hope this helps.
Best Answer01-12-2022 06:46
01-12-2022 06:46
me too. accidentally turned it on and i cannot turn it off unless i plug it in and reset. so frustrating.
02-01-2022 15:26
02-01-2022 15:26
Finally figured this out for anyone else still having this issue in 2022.
Quick touch buttons on both sides of Inspire 2 while in an active “exercise” mode. The pause screen comes up. If you touch the screen it will continue. Don’t do this.
Quick touch both buttons again for finish flags and stats. Do not hold the buttons it will go to water Lock Screen. Best to take it off to do the quick touch, covering both buttons. Kind of annoying it kept going back to water screen.
Hoping this helps some folks!
02-15-2022 23:31
02-15-2022 23:31
Brilliant - this worked perfectly. I’ve been incredibly frustrated not being able to effectively stop and finish my Fitbit when I’ve actually finished exercising. Now I can thank you 😊
02-16-2022 04:21
02-16-2022 04:21
Yay!! Glad I could help!
Quick touch both buttons together to pause and again both to finish the workout. Lol would’ve been nice to have it in the instructions for the watch :).
05-14-2022 08:59
05-14-2022 08:59
Get F****** real. 9 steps to get out of a mode that this buggy model somehow went into. How about 9 steps to initiate and 1 step to exit. Not happy with my recent purchase
05-14-2022 16:34
05-14-2022 16:34
You should be writing their manuals for them. Their own support documentation is very spotty.
05-29-2022 11:52
05-29-2022 11:52
Will hive this a try , thanks: I’ m totally frustrated and hating the inspire - loved my charge two but drowned it in a swimming pool…
Best Answer07-19-2022 18:41
07-19-2022 18:41
It is impossibile to stop. 1st of all it's hard to get the exercise io. I continually get water locked or unlocked. If I get the exercise and hit the button to stop it, it takes me to water locked and then time elapsed running. I tried holding the button and that did the same thing.
Best Answer07-19-2022 18:48
07-19-2022 18:48
I've been following your instructions repeatedly for more than an hour with no luck getting beyond water lock unlock running tine6. The screen also shuts down so quickly I often have to start from scratch. Maybe a video would help or a better designed watch.
