01-30-2020
14:48
19:25
YojanaFitbit
01-30-2020
14:48
19:25
YojanaFitbit
When a map does show on a saved exercise activity (it doesn't always), it's often shown incomplete on my Fitbit app, ie, I see a map of the last portion of my activity, and a couple of straight red lines instead of the actual route (and only a small part of that route).
The phone's GPS is on, the exercise activity runs properly, the device isn't paused during the activity, and the activity is saved correctly. All the data from the activity shows up on both the app and the Dashboard here.
Anyone know what's up? What am I missing here?
Fitbit is up-to-date, by the way, and I'm using a Samsung Galaxy S10e phone.
Thanks!
Best Answer01-31-2020 19:19
01-31-2020 19:19
Hey @SunsetRunner nice to see you around. Thanks a million for double checking every single step to use Connected GPS with your Inspire HR.
Sorry to hear that you're not able to see the GPS details of your runs on the Fitbit Dashboard. We’re aware of it, but may not be able to provide a fix in the immediate future. We'll continue to monitor the situation, and keep our team informed of the impact to you and other customers. We understand that this isn't the resolution you're hoping for, but rest assured we're always working to improve our products.
We appreciate your patience and look forward to getting you back on track.
Please let us know if you have any other questions.
01-31-2020 19:19
01-31-2020 19:19
02-01-2020 00:56
02-01-2020 00:56
Ditto with me, on Android also, didn't have this issue a week ago..... Frustrating!
02-01-2020 04:24
02-01-2020 04:24
Thanks for the very prompt reply!
Alan
02-03-2020 07:14
02-03-2020 07:14
Hey @SunsetRunner you're very welcome! I'll be around in case that you need anything else.
@Alishamly thank you for your feedback. This unexpected behavior is not happening with all users, but this issue has been escalated to our team and they are working on finding a fix. Sorry for any inconvenience while we're working on this and thanks a million for your understanding.
I’ll see you around the Community!
Best Answer02-12-2020 15:12
02-12-2020 15:12
Hi,
Just thought I'd let you know that the same thing is happening with iphones so please ensure the fix works for them too. It's only been a problem for me in the last few weeks.
cheers
04-20-2020 20:06
04-20-2020 20:06
Hi. I'm having a similar issue on an iPhone and Inspire HR (April 2020). I've also had problems where spot checking during the exercise the phone will occasionally say there is no device found.
Best Answer07-26-2020 02:43
07-26-2020 02:43
Having similar problems with Versa and iPhone 11 especially when cycling.
When hiking the watch easily goes into Pause mode by accidentally touching with backpack or similar!
Also overview map on exercise map shows details of a completely different day. Only when I click and enlarge the map does it show the actual exercise of the particular day¨.
After updating firmware it often complains that update did not work or Bluetooth connection is not right. After resetting iPhone and Versa all is fine. Not really an elegant solution.
Best Answer11-03-2020 13:13
11-03-2020 13:13
This has been happening to me with my Charge3 in iphone synched to it too. Seems to be happening more and more. Never used to happen in past years, and I've been wearing fitbits for years now.
04-15-2021 03:54
04-15-2021 03:54
So its April 15 2021 now, and there still isn't a fix? I'm using the inspire HR and the GPS takes nearly 2 minutes to connect before I can start exercising THEN it drops out early on... and all my exercises are incomplete. Whats the status on the fix? or is this a hint to purchase and renew my buying cycle?
04-16-2021 06:10
04-16-2021 06:10
It is now April 15 2021 and there still isn't a fix. I'm using the inspire HR and the GPS takes nearly 2 minutes to connect before I can start exercising THEN it drops out early on... and all my exercises are incomplete. What's the status on the fix? or is this a hint to purchase and renew my buying cycle and buy the Inspire 2? Is this a case of planned obsolescence, with a 1.5-2 year product life span? This is very disappointing.
