Hi,
I got the inspire 2 around February time and it has been working perfectly with a fully charged battery lasting over a week. Now in the last few days I charge the fitbit to full charge and within 2-3 hours the battery is drained to 0. I haven't updated and settings recently that would cause this sudden decrease.
Any help on what has gone wrong?
It's good to see you for the first time in the community @Rogal94.
Thank you for sharing the inquiry regarding your Inspire 2.
Before considering other options, please let me know if you have following the steps suggested in this article in order to avoid battery drain.
Best AnswerHi,
Yes, as mentioned no settings have changed in the last week that should cause the battery life to go from 7+ days to less than a few hours. I have it optimised for battery saving.
Thanks
I'm in the same position as you. The past week my watch battery is draining quickly and my stopwatch isn't working properly either. Keep in mind, the app on the phone was also recently updated so I think that has to do something with it. Hopefully fitbit can push another update out to correct this.
Its the new update on the app. Mine did the same thing until I disconnected it from the app. Now it's perfectly functional, but beware. It might not reconnect and they'll tell you you have to buy a new one if it's out of warranty.
