01-27-2023
12:42
13:40
JuanFitbit
01-27-2023
12:42
13:40
JuanFitbit
When attempting to pair my device with my phone its stuck on the pairing code screen and after 1 or 2mins sends me back to the today page and says 'Bluetooth must be enabled to activate tracker' Bluetooth is on
@Alversities , A warm welcome to the Community! Thank you for your message.
What mobile device are you using to pair your Inspire 2? (Phone model, please)
What operating system version has it on? (Android 10, iOS 13, etc)
In the meantime, please restart your Inspire 2 How do I restart my Fitbit device?
Turn your phone off/on again.
Make sure that the Fitbit App is allowed to use Bluetooth.
Try to setup the Inspire 2 again.
More can be found here: Why can't I set up my Fitbit device?
Best AnswerSamsung Galaxy A03s
Best AnswerMy mum's brand new fitbit inspire 2 is doing the exact same thing. I have done all the steps suggested, restarting phone, clearing Bluetooth devices, restarted fitbit, tried on 3 different devices but the same message about Bluetooth appears after putting the 4 digit linking code in. Any ideas where to go next? Very disappointing as a birthday gift for my mum.
@Alversities @ClaireA84 ,Thank you for your messages and further info.
Please on the mobile device, go to the settings> Apps>Fitbit App and clear the cache.
Restart your phone( on/off)
Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
Connect your device to the charging cable
Press and hold the buttons on your tracker for 10 seconds.
Release the buttons. When you see a smile icon and the tracker vibrates, the tracker restarted.
Try then to setup the Inspire 2 as a new device.
@ClaireA84 , Thank you for getting back.
Please follow these steps, some of which you have already done, but the order is important:
If you are using the Tile app, please make sure to deactivate it before the following:
Best AnswerI have done all of these steps, but still, my Fitbit will not connect to the app. Even after I have allowed Bluetooth in the app settings, it will not even show up in my Bluetooth settings. My problem started when I couldn’t figure out why the app stopped syncing to my device, and now I can’t even get my device to see the Fitbit. My iPhone will see and connect to other new devices though, what do I do now? I’ve been at this for hours.
@ClaireA84 , Nice to see you around. Thank you for sharing your experience. I'm glad to read that Amazon help you further.
@Brightfeather28 @Hicth , If you already tried the steps described above please try the following.
Do you have access to another mobile device? (eg. borrowed, old device, etc) where you can install the Fitbit app?
If so try installing the app on the alternative phone/tablet.
Turn the Bluetooth off of the main device.
Try setting up the Inspire 2 with the alternative device.
If successful, turn the Bluetooth off of your alternative mobile device and turn on the one from the main device.
Try to sync the Inspire 2 with the main device
