12-09-2020 13:36
12-09-2020 13:36
Hi I'm new here. Just purchased an Inspire 2 a week ago and I noticed that when I'm driving it's counting steps. What can I do to stop this from happening?
Thanks
12-10-2020 09:01
12-10-2020 09:01
@Wally59 Welcome to the Community.
Let me help you with this. Your device will detect the movement on your arm and translate that movement into steps. There are situations in which your arm may move but you won't be actually walking. For example, this may happen when you are playing the drums, burping a baby or clapping. It can also happen while driving. You can negate these steps by logging a driving activity. You can try wearing your device on your non-dominant hand but select that hand as dominant on the device’s settings to make it less sensitive to movement. Finally you can also try wearing your tracker in the clip mode to see if this helps reduce the steps detected while driving.
Let me know how it goes.
01-04-2022 13:51 - edited 01-04-2022 13:51
Logging the driving time worked in removing the added steps!
