09-30-2020
16:03
06:18
JuanJoFitbit
09-30-2020
16:03
06:18
JuanJoFitbit
Please help! I purchased one for my wife recently. The HR monitor worked for about an hour after it was 1st set up and now it doesn't seem to work. I've restarted the phone, the app, re-logged in and restarted the device. Nothing seems to work. I'm not seeing the flashing light on the underside of the device at all.
I'm wondering if it's defective and needs to be exchanged or if there's a setting issue I'm not aware of...
Thanks!
Moderator edit: format
01-22-2021 17:14
01-22-2021 17:14
Thanks, mine was on clip mode. Turned it on to heart mode and it worked.
01-22-2021 18:23
01-22-2021 18:23
I don’t understand why I am still waiting for assistance from the support team. I have tried all the suggestions about resetting from wrist to clip and back to wrist. Bpm is on and nothing works. If there aren’t any useful suggestions why haven’t you sent me a new device to try. If the new one works I will very happily send back defective.
02-17-2021
04:06
10:06
02-17-2021
04:06
10:06
@deaconronc, that's great news! I'm glad to hear that your Inspire 2 started to work properly again. Thank you for posting the update here.
Hi @Lestalk, I totally understand how you feel about the heart rate tracking issue. I was able to get in touch with our Support team and was told that they assisted you via email and sent you some instructions. Please reply to them in case more assistance is needed.
I'll be around if any question arises.
04-26-2021 06:48
04-26-2021 06:48
None of these options worked for me, so I tried fixing it on my own. I ended up fixing the heartrate monitor by not pressing, but holding down on both sides of my fitbit until dnd popped up. I simply scrolled down past sleep, past screen wake, past water lock and if yours says on clip then the heart rate monitor won't be on. You have to touch it to make it say on wrist and then it will turn on, at least it did for me. Best of luck.
04-27-2021
04:10
10:06
04-27-2021
04:10
10:06
@aaron1997 Thank you for participating in our Fitbit Community. I'm so glad to hear that you managed to get the issue resolved. Thank you for posting the steps you followed in order to get the heart rate monitor fixed. I'm pretty sure that this will help other users that experience the same issue.
As a side note, I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
See you around.
05-08-2021 11:20
05-08-2021 11:20
This is exactly the sort of unhelpful response that so called Fitbit Moderators produce. If you look at the posting chain here, you’ll see that the Moderator solved nothing! It was actually the user, aaron1997 that figured it out. The standard replies by the moderators suggest they are all bots anyway.
Thanks Aaron. No thanks JuanJo. Best of luck indeed!
05-18-2021 01:00
05-18-2021 01:00
Great fix! Nothing else worked! Thank you!
05-19-2021 21:19
05-19-2021 21:19
That worked for me thank you soo very much!!
05-24-2021
04:22
10:06
05-24-2021
04:22
10:06
@TwinPeaksBob I appreciate your feedback and comments since this helps us to keep improving.
@elaineconneely @Berry7 Thank you for participating in our Fitbit forums. I'm so glad to hear that you found this thread helpful and managed to get the issue resolved.
See you guys around.
07-21-2021 20:43
07-21-2021 20:43
@aaron1997 thank you! This was the only post tip that worked! You saved me more frustration.
07-22-2021
05:19
10:06
07-22-2021
05:19
10:06
@rmranran Thank you for participating in our Fitbit Community. I'm glad to hear that you managed to get the issue resolved by following the steps shared by @aaron1997. Thank you for posting the update here.
Hope to see you in our Fitbit Community more often.
01-10-2022 21:04
01-10-2022 21:04
I just spent 45 minutes trying to get my heart rate on, checking settings and the app etc. Your suggestion worked. Fitbit should pay you to rewrite their help section.
08-30-2022 11:42
08-30-2022 11:42
THANK YOU!!! After plugging Fitbit Inspire 2 into & attaching it to the charger, pinching sides for few seconds, then a smile appears. On the fitbit itself (not the phone app), under "Quick Settings(?)", choose (touch to make it light up) "clip", then "on wrist"(?) and it started keeping my pulse rate again. (The "?" means the words are something like that, but can't remember exact wording.) THANK YOU 💋 AGAIN!!
12-10-2022 19:19
12-10-2022 19:19
I have tried all the listed troubleshooting - my inspire 2 is set to wrist and heart
rate to on. I have tried rebooting, resetting data - which included repairing device. I also tried switching to clip and then back to wrist - nothing is working. It seems to have stopped right after my recharge that I did earlier today. Please assist!
12-10-2022 19:34
12-10-2022 19:34
12-11-2022 04:59
12-11-2022 04:59
My issue isn’t with sleep. The green light for the heart rate isn’t working. All troubleshooting has been attempted.
12-11-2022 05:06
12-11-2022 05:06
I also noticed that my battery is draining quickly. Was 100% yesterday afternoon and now is at 45% this morning.
01-29-2023 15:54
01-29-2023 15:54
This was helpful for me. thanks!
02-16-2023 20:45
02-16-2023 20:45
Switching from "Clip" to "Wrist" helped a lot.Thanks! My Inspire 2 switched to "Clip" somehow.
03-11-2023 08:26
03-11-2023 08:26
You probably You want to check in the app if you have the heart rate on 24/7 if not then it automatically turns off to save battery had the same issue lol.
