09-25-2020
23:00
13:44
AndreaFitbit
09-25-2020
23:00
13:44
AndreaFitbit
Hi! I received my Insipire 2 yesterday but I can’t get the HR to work... is there something I have to do? Never seeing the green light 😖
Moderator Edit: updated subject for clarity.
09-28-2020
21:21
03:02
JuanJoFitbit
09-28-2020
21:21
03:02
JuanJoFitbit
Same!!!!!!! I finally figured it out. I was soooo confused at first. Thank you!
Okay figured it out!
1. Press & hold sides
2. You should then see “do not disturb”, “sleep”, “water lock”, “screen wake”, “on clip”
3. Tap on clip and change to “on wrist”
4. Heart monitor should then work!!!!
Also, I am obsessed with this Fitbit
Moderator edit: merged reply
10-10-2020 10:42
10-10-2020 10:42
This fixed mine. Crazy to think you have to tell it that it is on your wrist and not on the clip. Why on earth would you have to tell it that?
10-30-2020
07:17
03:07
JuanJoFitbit
10-30-2020
07:17
03:07
JuanJoFitbit
I have the same problem. New device, just set it up today...the heart never flashed, never worked. In settings, there's only a "Heart Rate Notification" which is ON. There's no other "heart rate" setting. Did you get yours fixed?
On my settings menu, between GPS and Do Not Disturb, I don't have the "Heart rate"! That's why i can't turn it on i guess!! So frustrating!
"On the settings menu on your Inspire 2 you should see:
Dim screen (options are on or off)
Phone GPS (on / off)
Heart Rate (on / off)
Do not disturb (with sub menu)
Sleep mode (with sub menu)
Heart zones notifications (on off)
Double tap (on / off)
Clear user data
Reboot device
Device info"
11-03-2020 15:20
11-03-2020 15:20
Thank you so much. Been going back and forward for days trying to work this out and n all different forum threads.
cant believe it was something as simple as changing the “on clip” to “on wrist”
11-23-2020 13:56
11-23-2020 13:56
I am having the same issue as many others. My heart rate monitor stopped working as well as no led. I've scrolled through the settings, but there is no option to turn Heart Rate on or off. Any more tips?
12-26-2020 18:05
12-26-2020 18:05
Go in settings on device, delete your data.
Go on the phone App. And re add it as new ..
Tried everything is the only thing that works..
12-26-2020 18:56
12-26-2020 18:56
This worked for me to. It somehow turned itself off 2 days ago.
12-28-2020 17:24
12-28-2020 17:24
Thanks. Solution worked for me.
12-29-2020 20:39
12-29-2020 20:39
How did you take it off clop to make it wrist? I'm having the same issue
12-30-2020 09:48
12-30-2020 09:48
12-30-2020 12:32 - edited 12-30-2020 12:33
I made a video that shows you which two settings to check if heart rate isn't working.
You can watch it here: https://youtu.be/Frt6-7rt42M
12-30-2020 13:19
12-30-2020 13:19
01-09-2021
10:53
04:02
JuanJoFitbit
01-09-2021
10:53
04:02
JuanJoFitbit
Hold both sides of the Inspire and the quick settings will come up. Scroll all the way to the bottom and make sure the setting says on-wrist and not on clip. If it says on clip, tap the screen to on wrist and the green lights should come back.
Hold both sides of the device until DND shows on the screen and then scroll to the very bottom. Make sure it says on-wrist.
01-09-2021 14:11
01-09-2021 14:11
01-09-2021 15:28
01-09-2021 15:28
01-12-2021 14:47
01-12-2021 14:47
Thank you!! This solved the same issue I was having
02-11-2021 09:41
02-11-2021 09:41
Thanks SilviaFitbit, your solution (below) worked...
- Press and hold the buttons to access 'Quick Settings'
- Choose On Wrist/ On Clip setting
- Turn on On Wrist
Thanks
02-24-2021
04:05
10:59
02-24-2021
04:05
10:59
Hi guys, it's great to see that the recommended steps that were shared above helped you to get the issue resolved. Thank you for posting the update here.
As a side note, I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often! 😀
02-26-2021 19:16
02-26-2021 19:16
Feeling the same, just 10days in and no HR, I only decided to give FitBit another chance after the band on my Samsung broke:/ Thinking about bringing my Samsung back to life and getting another band, as it did not skip a beat on tracking heartbeat in over two years and is way more intuitive with regard to tracking activity, sleep, etc. with a simple touch screen to quickly select face/clock update w/out having to download anything vs. this inspire 2 with no options to even gain a color face:/ Anywho just another 2 cent vent before I return this fitbit if issues persist over the weekend...
02-26-2021 19:19
02-26-2021 19:19
Restarted and still no BPM beyond my resting heartbeat and have only had this fitbit for 11 days:/
