Hi all,
I lost my FitBit inspire 2 last week and Im sure the battery has died.
Ive used apps such as LightBlue, fitbit finder and ble scanners but they havent helped. Ive searched in and out yet it still hasnt revealed it's self. Any help would be appreciated 😀
Hi @Tanmyster with a dead battery there is nothing you can do. If you sync and it's within range, you can see the remaining battery strength on your app. The only thing you can do is an intensive game of hide and seek to find your Inspire 2. There isn't anything that can be done once the battery has died.
00:42
10:24
ManuFitbit
09-11-2023
00:42
10:24
ManuFitbit
Thank you but I have already done that. Is there any other way to get my fitbit back?
Also LightBlue can identify it but it cant receive a signal or locate where it is
Best Answer@Tanmysterwith a dead battery, there is no way for you to use LightBlue or any similar app to locate the missing Fitbit. Unless you can recall where you last had it in your home, you might never find it. If you have a pet, check to see where they put their treasures. Cats and dogs often hide things from us. Sorry, but there really isn't anything more Fitbit can do.
