11-06-2021
00:59
23:01
11-06-2021
00:59
23:01
My Inspire 2 is not charging. Tried different USB ports and also mains power with no luck. I have also cleaned the contacts on the back of the watch and on the charger and also rebooted the device. I don't know if turning the device completely off and on again would help but I don't know how to do this. How do I know if the device is faulty or if the charger is faulty?
04-30-2022
10:00
08:36
04-30-2022
10:00
08:36
Hi, welcome to the Fitbit Community forums, @Narnah_ama.
Thank you for sharing that you've been having the same inconvenience with your Charge 5.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they've sent you some instructions. In this case, they will let you know how to proceed.
Have a good day.
11-06-2021
17:16
10:15
11-06-2021
17:16
10:15
Hello, welcome back to the Community forums, @Pam_Health.
Thank you for the information provided regarding the inconvenience that you're experiencing with your Inspire 2 device.
If this is related to the battery, please make sure that you've followed all the other recommendations provided in this article, as they have been useful for other users experiencing this problem.
If the device is charging, but the screen is completely black, make sure that you've also completed the restart procedure described here.
Hope this helps, I'll be around.
11-10-2021 11:19
11-10-2021 11:19
I have the same problem after using it for 9 months and nothing works. I cannot recommend Fitbit.
11-11-2021 03:52
11-11-2021 03:52
Thanks for your response. I have made sure that I've followed all the recommendations provided on the link to the article on 'why is my battery not charging'. The screen is not blank, it's flashing 2% battery. Nothing I do gets the battery to start charging.
11-11-2021 13:11
11-11-2021 13:11
I’m having a similar problem. My device has been on charge on and off all day. Cleaned contacts, won’t even switch on Not responding in any way at all and device is just feeling warm to touch. Had Fitbit around 6 months and after having no problems with my Fitbit 1 the inspire 2 has not been my favourite tracker!
11-12-2021 22:40
11-12-2021 22:40
I'm having the same problem. I plugged my Fitbit in to charge at 27% at 7:00 at 10:00 it was at 24% I got the Inspire 2 when it was first released I'm not sure I've had it a year. I rely on my Fitbit. Does Inspire 2 have a warranty?
11-18-2021
15:37
08:37
11-18-2021
15:37
08:37
Hi, thank you for all your replies, and welcome to the new users in the Community, @Reghis @Pam_Health @Barleygirl42 @Booshouse.
Thank you for confirming that you already tried the recommended troubleshooting steps and that you continue to experience the same difficulty. In this case, I recommend that you get in touch with the Customer Support team for further assistance, so they can let you know how to proceed. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Have a good day.
04-27-2022
07:45
10:01
DavideFitbit
04-27-2022
07:45
10:01
DavideFitbit
Hi Pam! I got my Fitbit Inspire 2 a couple of months ago and I’m having the exact same problem! Did it get fixed?
Moderator edit: format
04-30-2022
10:00
08:36
04-30-2022
10:00
08:36
Have a good day.
06-25-2022 14:42
06-25-2022 14:42
Mine did this after 3 months, they sent a replacement and after 3 weeks same problem. Will have to get in touch again.
07-08-2022
09:19
08:29
07-08-2022
09:19
08:29
@Janicesetter Thank you for sharing your experience with this. I'm sorry to see that you experienced this problem with the replacement device sent to you.
In this case, and if you already tried all the steps listed here, I do recommend that you continue the communication with the Customer Support team so they can provide you with the next steps. You can click here to get connected.
10-15-2022 13:38
10-15-2022 13:38
I haven’t gotten any. I got the the new fitbit from myntra and I guess they have sent a bad charger I tried different methods it’s not working
10-29-2022
11:33
10:15
10-29-2022
11:33
10:15
Hi, thank you for confirming that you've been having the same inconvenience with your Charge 5 and for confirming that you already tried a few troubleshooting steps, @123Gauris.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they provided you with some instructions. In this case, they will let you know how to proceed.
Have a good day.
02-14-2023
10:15
10:04
DavideFitbit
02-14-2023
10:15
10:04
DavideFitbit
Make sure to hold down the sides of the fit bit, go to the settings where you can either have it on your wrist or on the clip. Make sure it’s on the clip. Instantly worked for me once I did this.
Hold down the sides and go to the settings where you can have it on the clip or on your wrist. Make sure it’s on the clip. Worked instantly once I did this.
Hold down the sides, scroll all the way to the bottom to where you can either have it on the wrist or on clip. Make sure it’s on the clip. Instantly worked for me when I did this. How you can tell is the green light won’t be on. Then that means it’ll charge.
Did you have the fit bit set to being on the wrist? With a green flashing light? Turn it off. Hold down the sides and scroll down to where it shows either on wrist or clip. Make sure it’s set to being on the clip. Now it will charge. If it’s turned off already this may not work. If you are getting email updates and text updates about your fit bit running low on battery I’d pay attention to that. What you might be able to do is go on your phone and see if you can do it manually that way. Set it to being on a clip so it can charge.
Settings need to be on “clip” or it won’t charge. Tell your customers that.
Hold down sides where it goes to quick settings, scroll down to screen wake, make sure it’s on clip. Then it’ll charge. The device is not broken.
Make sure the quick settings is set to “ON CLIP”. It shows the actual charger. If the green light is on then it’s set to wrist. Hold down sides, scroll down to the bottom and make sure it says clip.
