08-22-2022 09:10
08-22-2022 09:10
Any suggestions as to why my Inspire 2 has stopped vibrating for goals or notifications and how I can resume please?
08-22-2022 13:09
08-22-2022 13:09
I’m happy to help @Alusia 😃 Please consider marking my solution above as “Best Answer”. Doing so helps others find answers quickly to the same issue you were experiencing. I’d really appreciate it. I hope you enjoy the rest of your day and as always Happy Stepping!
08-22-2022 12:32
08-22-2022 12:32
Hello @Alusia
Check to make sure that DND Mode and Sleep Mode are off (the icon is not illuminated). Both of those options will stop the Inspire 2 from vibrating. DND is particularly easy to turn on by accident because it is the first option up when you press and hold the side buttons.
😃Please let me know if this provides you the best answer and gets your Inspire 2 vibrating again. Keep me posted
08-22-2022 12:58
08-22-2022 12:58
Hello,
Thanks for that. I had accidentally switched on sleep mode (which I never realised existed!)
All sorted now, thanks again
08-22-2022 13:09
08-22-2022 13:09
