Hi there, @Mishaya @marionwalker. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Inspire 2 devices before reaching out.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Inspire 2 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Inspire 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Inspire 2.
Hope that helps.
Yeah i eventually got it going but now it wont put the steps in my trainerize fitness app i was putting the wrong make of the fit bit in there
Best AnswerHoi
I have the same problem. I have a Samsung S7
My fitbit just stopped syncing. I tired everything you said. I removed, replaced and re-booted and got stuck at the same step.
I get asked for the 4 digit number.
I type it in and then wait for connecting and it fails!
Then it says the usual Bluetooth on/off or contact you.
The blue tooth works because the device is found.
Im stuck in a loop any ideas
Best AnswerAny luck, I have the same issues
03:05
10:34
LizzyFitbit
04-10-2023
03:05
10:34
LizzyFitbit
Hoi
I had to reset and re-install to get it to work.
I’ve had to do this twice in the last 14 month but east after first time
Andrew
Moderator Edit: Formatting
