06-09-2022
04:52
22:22
06-09-2022
04:52
22:22
I recently wore my Inspire 2 long distance swimming. It now has some condensation on the screen. It no longer vibrates with texts or "win the hour" notifications but I can still read texts on it. I can no longer press the DND button either. Any suggestions?
Hi @merp123. Have you tried a restart? Also, it's possible there might be water under the screen. I would put it in a bag of rice and see if that helps absorb some of the condensation.
Best Answer@merp123 Take a look here at the Inspire 2 manual. Open the Settings and tap on Reboot Device. Hopefully that will help.
