04-03-2019 19:54
04-03-2019 19:54
I am certain many people bought the inspire with the clip to replace their Fitbit Zip. Is there anyway to primarily display step count? None of the clock faces seem to do this. Why not? Should be an easily developed clock face!
04-05-2019 08:39
04-05-2019 08:39
@JenniS2640 If it is accidentally tapped or touched (sometimes the fabric of my sleeve with change the stat), then the stats will cycle.
Swiping up from the bottom of the clock face will also give you your steps for the day too. But on clock faces where you can tap the screen, accidental touches will likely cause the stats to cycle.
04-04-2019 04:35
04-04-2019 04:35
@MatGregoski There are many clock faces that display steps, however if you tap on the screen it will show other stats, like the date.
Select a clock face and then tap on your Fitbit screen. You’ll see steps. 🙂
04-04-2019 21:42
04-04-2019 21:42
Why doesn't the step counter stay on the clock face? I have changed clock faces a couple of times and each time after a couple of hours the clock face changes to calories burned or distance travelled.
04-05-2019 08:39
04-05-2019 08:39
11-11-2019 12:22
11-11-2019 12:22
I was wondering about this as well, and recently searched for how I can have my Inspire only show steps. I'm not interested in calories burned, distance, exercise minutes, etc. Is it not possible to have the screen only display step information (similar to how we can customize our online dashboard to remove those tiles?) Thanks in advance!
11-11-2019 21:34
11-11-2019 21:34
Best Answer06-16-2020 17:50
06-16-2020 17:50
I just got mine and it does this too. I want it to show steps first on the face without scrolling through the rest. Even the Valerie face shows steps but now after an hour or so when it raises under the time it now shows HR! Ever find a fix?
06-16-2020 19:48
06-16-2020 19:48
Best Answer02-12-2023 09:38
02-12-2023 09:38
Is there a place where I can request a clock face that shows primarily steps in nice big numbers? With all of the clock face options, and this being primarily a device that tracks steps, I feel like that's a pretty reasonable thing to add to that list.
