01-10-2020 15:51
01-10-2020 15:51
I've seen many posts about how to set the Inspire HR Alarm and other issues related to the alarm. However, I've not seen any posts on how to disable/turn off the alarm once it's "done its job". I keep tapping my Fitbit, sliding it, etc, but it keeps going off every 5 minutes or so for several times and it's driving me crazy!
Any advice, please??!! Thanks 🙂
Best Answer01-10-2020 17:54
01-10-2020 17:54
I can tell you about the Versa 2 and guessing Inspire HR is the same. When it goes off, the display shows a quarter-circle arc in the lower right corner of display. Tapping in that area, bottom right, disables the alarm.
Best Answer01-11-2020 07:51
01-11-2020 07:51
Wrong guess! It does not. Walking 50 steps does turn it OFF. (dismiss the alarm).
UGH!
01-17-2020 19:40
01-17-2020 19:40
Disabling Inspire HR alarm was NOT the same as Versa - sorry.
I haven't tried walking 50 steps, as another person suggested, but that seems a bit crazy to do in order to have to turn off an alarm! Surely, there's got to be a better way.
04-09-2020 08:57
04-09-2020 08:57
I'm so disgusted with the Inspire HR. that I forgot to reply. (so many additional "features" but no day-of-the-week, not easy tap to reset alarms, hard to see outside, hard to read manual shared, etc.)
IF you push the side button two or more times ONLY while the alarm is vibrating, the alarm is canceled.
Bring back my Alta!! It is all I wanted.
Best Answer04-09-2020 11:28
04-09-2020 11:28
Best Answer04-09-2020 11:31 - edited 04-09-2020 11:40
Understandable!
Best Answer04-09-2020 11:35 - edited 04-09-2020 11:38
Thanks for the try; I figured out walking 50 steps, or even 5000, wasn’t gonna stop that blessed alarm from vibrating!!!!
Best Answer04-09-2020 17:08
04-09-2020 17:08
It worked, pressing the button on the side 2-3x while alarm is going off was the answer - thx!!!
